Recently updated to 2022 font (Heiti SC reg) displaying on sheet but not displaying properly in pdf created using DWg to PDF.PC3
lauraQH6G3
Message 1 of 29
lauraQH6G3
Hi!
I and others in our practice have recently updated to 2022. We use the font Heiti SC regular. This displays when in autocad but once PDFed using dwg to pdf. pc3 the text errors as in the below screenshot. The font is correctly installed on the system, it has been replaced, to check it is not corrupt, this had no impact. Solution welcome?! tried allsorts and had no luck so far. I am on Mac OS Monterey 12.2
Replies (28)
Message 21 of 29
lauraQH6G3
This is the print window
Message 22 of 29
maxim_k
@lauraQH6G3 ,
Are there raster images attached in your drawings with this problem?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 23 of 29
lauraQH6G3
No I don’t think so, the issue only occurs when the sheet has been PDFed within autocad everything displays fine. There are no images in the autocad file other than one png logo which is obviously unaffected by the issue
Message 24 of 29
maxim_k
Have you tried to remove this logo image - temporary - and test saving to PDF?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 25 of 29
lauraQH6G3
Detaching this image has no impact on the pdf export/print, I unfortunately still have the front/text issue
Message 26 of 29
maxim_k
@lauraQH6G3
Have you tried to change printer from DWG to PDF.pc3 to AutoCAD PDF (general documentation).pc3 ?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 27 of 29
lauraQH6G3
Unfortunately I have the same problem with all the pdf printer options in autocad, I have just checked the one you suggested again and still have the same issue
Message 28 of 29
maxim_k
Laura,
I got a chance to test Heiti font on macOS Monterey, and I can confirm the problem you have with it.
I see two workarounds here:
- use "Convert all text to geometry" option as it was suggested earlier
- find a replacement for this font
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 29 of 29
lauraQH6G3
Okay thank you for your help, I will continue to convert to geometry and then hopefully there will be a hotfix
