Recently updated to 2022 font (Heiti SC reg) displaying on sheet but not displaying properly in pdf created using DWg to PDF.PC3
lauraQH6G3
Message 1 of 29
lauraQH6G3
Hi!
I and others in our practice have recently updated to 2022. We use the font Heiti SC regular. This displays when in autocad but once PDFed using dwg to pdf. pc3 the text errors as in the below screenshot. The font is correctly installed on the system, it has been replaced, to check it is not corrupt, this had no impact. Solution welcome?! tried allsorts and had no luck so far. I am on Mac OS Monterey 12.2
Replies (28)
Message 2 of 29
pendean
Community Legend
Community Legend
Which PDF driver did you use and how is it set to handle/capture fonts?
Message 3 of 29
lauraQH6G3
I used DWG To PDF.Pc3
Unsure what the second question means sorry
Message 4 of 29
lauraQH6G3
Message 5 of 29
maxim_k
Hi @lauraQH6G3 ,
Try tu use "Convert all text to geometry"
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 29
lauraQH6G3
Thanks Maxim, that is what I have been doing as a temporary fix. Will continue to do this until I there is a full solution.
Message 7 of 29
maxim_k
Laura,
>>>>Heiti SC regular
Is it commercial font?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 29
pendean
Community Legend
Community Legend
As a test only, does the visual aspect of those fonts improve if you select this option?
Message 9 of 29
lauraQH6G3
Standard Mac Font which comes on the system
Message 10 of 29
lauraQH6G3
Yes this is what I have been doing as a short term fix
Message 11 of 29
maxim_k
Then I will check it on my side.
What macOS version do you have on your Mac?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 29
lauraQH6G3
Thanks!
Message 13 of 29
maxim_k
I cannot reproduce this issue on macOS BigSur 11.6.3
 Have you installed >>>this<<< Update?
Can you share your drawing here?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 14 of 29
pendean
Community Legend
Community Legend
Can you share your PDF with the odd-looking text here please?
A portion of your DWG with that same text in it would be nice too, if you can.
Message 15 of 29
lauraQH6G3
Thank you I will try this
Message 16 of 29
lauraQH6G3
Hi, this update will not work as I have autocad LT, is there a LT version of the update?
Message 17 of 29
lauraQH6G3
Please see files attached
Message 18 of 29
lauraQH6G3
All the following are installed
Message 19 of 29
maxim_k
>>>>>this update will not work as I have autocad LT,...
Sorry it was my fault.
But now I see that you have all the updates installed.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 20 of 29
maxim_k
Hi @lauraQH6G3 ,
I tried to save PDF form your drawing and all text looks correct (see attached PDF).
As I wrote before, I have macOS Big Sur  on my Mac, maybe the case of incorrect font representation is macOS Monterey, but I'm not sure.
Please post screenshot of Print window at the moment when you save drawing to PDF.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
