Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
"Configuration file may be locked by another process or ..."
7 REPLIES 7
Message 1 of 8
10499 Views, 7 Replies
"...have been set Read Only".
when I open a dwg file, it shows me this alert and i cannot continue. the software had been working for months untill today.
PLEASE HELP ME, IT CAN'T BE SO DIFFICULT TO REPAIR IT
7 REPLIES 7
Message 2 of 8
maxim_k
Have you tried to restart your Mac?
If this doesn't help - try to reinstall AutoCAD: remove it with "Remove AutoCAD" application and then install again. You need to leave "Leave application preferences" checked during removing AutoCAD in order not to loose your customisations.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 8
in reply to: maxim_k
you were right, i had just to install it again! thanks:)
Message 4 of 8
maxim_k
So now it works?
If yes, please mark my post as a solution -this will help other users to find the solution for such problem quickly.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 8
I have the same problem. After reinstalling it, it worked for a week then the same problem appeared again. And I seriously don't have the time nor the patience to uninstall and install it every week. Is there really no other solution?
Message 6 of 8
I have done all of this and still have the issue. What else is causing this problem?
Message 7 of 8
same problem, try everything and have use the all day on this problem. reinstalled and installed like 35 times, restart no restart reboot ALT that. Why is that sooo hard? Why is there no better way to do it.
Message 8 of 8
I did a Repair of the install and it got rid of the error.
