Properties Palette - AutoCAD LT for Mac 2017.1
earthsquare
Message 1 of 11
earthsquare
In the new palette arrangement, after the latest update ( AutoCAD_LT_Mac_2017.1 ), the Colour option is placed above the Layer option.
Ideally, when the colour is the property of a Layer, Layer should have been first.
I think its arranged alphabetically.
Have anyone felt the same ?
Regards
Sreejith.S
Sreejith.S
Landscape Architect
Replies (10)
Message 2 of 11
lionel.bekale
Hi Earthsquare,
Welcome to the community,
Can you please attach a screenshot to the post?
Have you tried to reset the application to defaults?
However, I do not think you need to reset the application to defaults as you get the same result in both cases. See the attached screenshot <Layers palette.jpg>  to see what I have before and after installing the AutoCAD LT for Mac 2017.1 update.
The video below shows how to manage the list of properties. See Managing your layers palette in AutoCAD for Mac 2017.
I believe that when you installed the AutoCAD LT for Mac 2017.1 update everything went back to normal. But you can still manage it as shown in the video.
Please keep us posted on the progress.
Lionel Bekale
Technical Support Specialist
Link Name
Message 3 of 11
lionel.bekale
Hi Earthsquare,
Lionel Bekale
Link Name
Message 4 of 11
earthsquare
Hi Lionel,
That wasn't a problem but I was trying to understand how others would have preferred it to be.
Just wanted to know if LAYERS were the first option, then colours and very other property.
Thanks for the reply.
Regards
Sreejith.S
Sreejith.S
Landscape Architect
Message 5 of 11
maxim_k
Hi Sreejith,
Never payed attention to that. But Color property was always above Layer property in the Properties palette in AutoCAD for Mac and in AutoCAD for PC.
Here is screenshot of the Properties Palette in AC 2016 for Mac:
Here is screenshot of the Properties Palette in AC 2018 for Windows:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 11
earthsquare
Hi Maxim,
Yes, but something is missing in this update...
...not sure, but when you pull down the "LAYER" button was there an option to change the colour along with the layer ( in a single pull down ) in older versions ?
This is not an issue... but suddenly after the update i feel something is missing.
Regards
Sreejith.S
Sreejith.S
Landscape Architect
Message 7 of 11
maxim_k
You still can do this in Layers palette:
Such option never was available in Properties palette.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 11
Emmsleys
@earthsquare
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks. Smiley Happy
Sarah Emmsley
Message 9 of 11
earthsquare
This was not a query which required a solution. It was a discussion.
Sreejith.S
Landscape Architect
Message 10 of 11
thereforestudio
Community Visitor
Community Visitor
Hi all,
I feel the same!
Previously there was a certain portion of the 'layers' palette options / buttons available above the properties palette (see screenshot 01)
Since the most recent update there is only the option to have all layer options / buttons broken off in the floating 'layers' palette (see screenshot 02) or all attached (screenshot 03)
You can still edit the layer of an object using the properties palette as you always could, however its not nearly as easy an interface.
Also, the properties palette reduces to its maximum width every time I open Autocad which makes it more annoying as it is too hard to read the names of the layers at such a thin width.
Best,
Alex
Message 11 of 11
thereforestudio
Community Visitor
Community Visitor
Hi Emmsleys,
Were you or someone at Autodesk able to respond to my post above on this matter? I believe that people did not understand @earthsquare 's question, and that I have provided a clearer description of the difference since the update.
Alex
