AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Projection angle
4 REPLIES 4
715 Views, 4 Replies
Projection angle
How can i change the angle projection on a mac
4 REPLIES 4
SeeMSixty7
You might need to expand that a little bit. I'm not sure what you mean.
Do you want to draw at a particular angle?
Do you want to rotate your User Coordinate System?
Do you want to change the snap angle?
To draw a line at a particular angle you can simply type your input at the command prompt.
LINE[Enter]
[Pick a point or type on in]
@5<30[Enter]
the @ means relative to the last point you selected
The 5 is the distance in whatever your drawing units are
the < means ANGLE of
30 is the angle in degrees. (Counter Clockwise from 0 which is along the positive X axis
To Rotate your UCS you can simply use the NAVVCUBE in the upper right corner to select one of the predefined faces or iso views.
Or you could follow the prompts in the UCS command and create a NEW UCS in one of many ways
You can also use the 3DORBIT command and jusat play around with the angles.
To Adjust the snap ang simply type in SNAPANG[Enter] and then type your  Angle
If you want isometric angle, you can use SNAP[Enter] Style [Enter] I for isometric
Hope some of that helps. If not give us some more info to work on .
Good luck
GrantsPirate
in reply to: SeeMSixty7
You may need to provide more info.  Maybe VIEWSTD command, pick first or third angle projection.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
i have problem
how to switch third angle to first angle projection in autocad in macbooks
maxim_k
Welcome to Autodesk Forums!
Hi @Anonymous ,
@Anonymous wrote:
i have problem
Do you already have third angle projection in the drawing?
Model documentation is not available in AutoCAD for Mac, if you mean it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
