AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
problems with plot model - window
4 REPLIES 4
kajzarVLVFQ
276 Views, 4 Replies
hello, i have a problem with autocad LT for mac. when I select plot model - window - when selecting the print window with the mouse cursor, autocad stops or turns off completely. this is not the case when selecting print via the display option. it is very annoying and unproductive. HW: macbook pro M2 max.
4 REPLIES 4
maxim_k
in reply to: kajzarVLVFQ
Hi @kajzarVLVFQ ,
Please specify AutoCAD version you use and macOS version installed on your Mac.
Have you installed latest Update to your AutoCAD?
Do you have this problem with all of your drawings or with just one?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
kajzarVLVFQ
in reply to: maxim_k
hi, thanks for your interest. i have autocad lt 2024 and mac os sonoma 14.2.1. the problem affects all drawings. I usually have 15-20 drawings open, which I switch between. after restarting the application everything goes normally, after a while the problem appears..
maxim_k
@kajzarVLVFQ ,
Have you installed >>>>THIS<<<< Update?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
kajzarVLVFQ
now yes :). everything works correctly. thank you very much!
