problems with deleting lines
Hi, i have done my first steps with AutoCAD.
i`m using AutoCAD on Mac. By deleting lines, there are strange things in background. i´ve done a screenshoot.
the screenshot shows a deleted line and a not deleted line.
perhaps someone does have an idea.
thank you
vinodkl
It looks like some graphic issue.
Here is a thread similar to yours: https://forums.autodesk.com/t5/autocad-for-mac-forum/autocad-2021-having-to-regen-all-the-time-graph...
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
maxim_k
Welcome to Autodesk Forums!
Hi @Anonymous,
It is knowing issue with some Radeon graphic cards.
Please look here for workaround:
https://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticle....
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Thank you, the change from „metal“ to „open gl“ has solved my problem.
thank you
