Problem when importing a block in a current drawing
alabrk
alabrk
Hello everyone,
I am working on an interior master plan in CAD LT 2022 and when I click in my block library to import a block, the block becomes a Xref... I tried dragging the block in my drawing from the source folder but the same thing happens.  I don't understand why it worked so well before that and now I can't import it properly. I can however import other blocks in the drawing without a problem. Can anyone help? Thank you!
maxim_k
Hi @alabrk ,
What do you see in the Command history, when you insert this block?
Can you share this drawing (block) from your Blocks library?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
pendean
Community Legend
Community Legend
Enlarge our commandline for now to be many lines taller, try it again, and see what is AutoCAD reporting/doing in more detail, then share that info here with us please
alabrk
For some reason, when I open the drawing with the block, it imports it like a simple dwg drawing and none of the attributes or parameters are applied... For now, I drew a new block with the parameters and attributes I needed but I don't understand how the file ended up "exploding" the block...
alabrk
maxim_k
Hi @alabrk ,
I'm able to insert your drawing from Blocks Palette and everything works out as it should.
The drawing you attached - BULLE DE REFERENCE.dwg contains authoring elements and when you open it in full AutoCAD version, AutoCAD gives an alert:
So if you select Yes, it opens in Block Editor.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
pendean
Community Legend
Community Legend
The file you posted is the actual dynamic block, yes?
It works fine when I insert it in the many ways AutOCAD2022 allows as well, it never changes to an XREF.
Your expanded commandline is not indicating anything about an XREF: how are you getting that information?
Could the real problem be your file already contained a block with the same exact name, but it is NOT a dynamic block, and you assumed without confirmation that it is an XREF (when it is just a regular block insert)?
THat's what I am seeing in your screenshots so far.
