Problem having Fields update in Project Manager
chris.vriend
chris.vriend
I am using AutoCAD LT 2020 for Mac and I keep having the following issue:
When using the Project Manager, I can update the layout name and number for a sheet that I've included in the Project, but this doesn't seem to update the relevant fields within the drawing, and whenever I try to include a Field, to add the drawing number to the titleblock for example, it has no effect.
If I use a sheet set from a project created in AutoCAD I can see the previous field values, but they also don't seem to update with changes to the Layout Name or Layout Number in the Project Manager window.
Help please!
maxim_k
Hi Chris,
I cannot reproduce this issue on my side.
What macOS version are you using?
Do you have tis problem only in one Project or in all Projects?
Please, post screenshots of Project Manager, Insert Field window with Field(s) properties you insert to the drawing, and drawing itself.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
chris.vriend
I am running Mac OS 10.15.7 (19H15)
I have had this problem both on new Projects, and on Projects with Sheet Set files imported from AutoCAD, but for some reason when I try to reproduce the problem to make the screenshots today, it seems to be working.
Thanks for your attention, and I'll up date this if the problem re-occurs.
