poly line join
poly line join
poly line join
for years I used a .lsp routine to make a polyline form multiple lines, finally in autocad 2015 for mac, it stop working... why???
maxim_k
Welcome to Autodesk Forums!
The lisp file you attached seems very complex to debug it in a minute.
Did you use it in PC version of AutoCAD?
What kind of error do you get when you are trying to use it?
You can also ask your question here:
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
yes I used it in at least 4 versions of autocad for PC, and it works ok
I call tis .lsp with  PJ
the error is:
Command: PJ PJ ; error: no function definition: ACET-ERROR-INIT
maxim_k
This function is defined in Express Tools, which are not available in AutoCAD for Mac, so you cannot use them.
You can try to cleanup your routine from this (and another one acet-error- function) and than load and test the routine,
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
BTW, have you tried JOIN command? Or it doesn't suit your needs?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
thanks.
I havent notice the JOIN command.
