AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Plotting with Adobe Acrobat Writer
3 REPLIES 3
eltorreBE558
916 Views, 3 Replies
Hello all,
I am having troubles plotting on AutoCad. I need to convert it into an Adobe PDF, but that option doesn't appear on the printer section. I have already downloaded the Acrobat Writer, and I was told that it would just show up afterwards, but it doesn't. I'm wondering if anyone knows how to do this.
Greatly appreciated,
3 REPLIES 3
maxim_k
in reply to: eltorreBE558
Welcome to Autodesk Forums!
Hi Elizabeth,
What AutoCAD for Mac version are you using?
If it is 2018 or later version, then you don't need Adobe Acrobat Writer for creating PDFs.
You can use one of the predefined AutoCAD PDF printers to save  drawings to PDF (Adobe PDF) format.
In Print window open "Printer" drop-down list and select one of "AutoCAD PDF... .pc3" printers:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
eltorreBE558
in reply to: maxim_k
I have the 2021 version of AutoCad. I have tried that, but every time that
I preview the page or when I do convert it into a PDF, the lines are
extremely thick, and I don’t know how to fix it.
Thank you for your help,
Elizabeth
maxim_k
@eltorreBE558 wrote:
...., the lines are extremely thick, and I don’t know how to fix it....
If you print (save to PDF) from Layout, then be sure to uncheck "Scale lineweights" option in Print window:
 If you use Plot Style for printing, then check that lineweights set correctly in it.
If you assign lineweights to objects or to Layers, then check if they are assigned correctly.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
