plotting autocad layout to pdf it changes color
Hello, so I have an AutoCAD file and I have created a layout and have various layers with line types. But I have a problem when I see it before transforming to pdf the colors are fine and the line types are okay. But then when I press plot all colors changes and line types to. I try plotting with acad, monochrome, grayscale all types but it does not work.
The first picture is how I see it.
how i see it in layouthow i see it in layoutwhen i plot it all changes the line weight  and colorswhen i plot it all changes the line weight and colors
rkmcswain
In your PAGE SETUP, are you using a plot style (CTB or STB)?
These can alter the on screen appearance in the print.
Run the PAGESETUP command, choose your layout and look at the settings.
Post a screenshot of that dialog if needed.
R.K. McSwain     | CADpanacea | on twitter
I have looked at the settings I have used all the options show below and the problem keeps happening.
Grover_Puma
in the autodesk support you will find more help on this topic. here is the link
https://knowledge.autodesk.com/support/autocad/learn?cg=Learn&p=ACD&v=2021&sort=score&page=1&prodFea...
ACEPTA LA SOLUCION que responde a tu pregunta, esto ayudará a otros a encontrar respuestas de una manera mas sencilla.
Si te gusta esta publicación, dale ME GUSTA.
Saludos!
maxim_k
Welcome to Autodesk Forums!
Hi Maria,
It seems you have transparency assigned to some objects in the drawing, right?
If I’m right, then before saving to PDF it is necessary to set the “Print Transparency” checkbox in the page settings (or in the “Print” window):
 As about line types, I cannot say for sure, because it is difficult to see the difference in line types from your screenshots.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
