Plotstyles not printing lineweight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Im having great difficulty in getting different line weights to plot using plot styles.
I have tried numerous ways of setting the plot style just as exercises to see if I can work out what is going wrong by process of elimination.
No matter what I set the lineweights to in a plotstyle, even with everything set to 0.00 thickness I get a thicker line than I would expect, probably something like 0.25.
The only workaround I have found is to set the lineweight in the layers property and then print to 'as displayed'.
However, my drawings are not set up to print this way and I really would like to work out what is not allowing the plot styles to be used.
Curiously also I have all my units set to metric yet in the layer table they are shown as imperial. ie 0.20" etc. and I cant find a way of changing this.
Its not my plotter because the output is the same on different printers and other peoples pdf's plot perfectly with nice fine lines.
I have attached a file for reference.
Thanks in advance.
