Plot styles
Plot styles
Plot styles
Help when I click on edit page setup I don't get a plot style table pop up and it keeps plotting with colored line weights,
maxim_k
Welcome to Autodesk Forums!
Hi Nkul,
Please specify your AutoCAD version and macOS version.
Can you attach screenshot of Page Setup you mentioned in your post?
There should be Plot Style section in it, where you can select plot style. Also don't forget to check mark "Plot with plot styles" option under Plot Style drop down list.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
john.vellek
HI @Anonymous,
I sounds like your file was created based upon a template using CTB Plot Styles. I suggest creating a new file based upon one of the Named Plot Style templates. You can then copy your model into the new file and import your layouts. After these steps you should be able to use Named Plot Styles (STB).
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or question. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
