Path not found
Path not found
Message 1 of 14
Path not found
Hi I reinstalled autocad for mac. but when I try to open a new job the Path Not Found warning appears and does not open the program. if I try to open an old file it doesn't recognize fonts, it doesn't make me change the thickness and it doesn't find the types of lines. I ask you for help, the assistance has not been able to help me.
Replies (13)
Message 2 of 14
maxim_k
Welcome to Autodesk Forums!
Hi Andrea,
What was the reason for reinstallation?
Please specify AutoCAD version you are using and macOS version installed on your Mac.
How are you trying to launch AutoCAD when this message appears?
Can you share screenshot of the message?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 14
I reinstalled autocad for this reason. the problem arose when i installed
catalina.
i have autocad 2019.
Message 4 of 14
maxim_k
Have you installed this Update?
https://knowledge.autodesk.com/support/autocad-for-mac/downloads/caas/downloads/content/autocad-for-...
If no, install it and try how it will work with the Update.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 14
It would seem that with this that I did download refunctions as originally.
Thank you very much. Greetings.
Andrea
Message 6 of 14
maxim_k
Very well!
Please mark "Accept as Solution" if my reply resolved the issue, to help others in the community.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 14
I am having this problem launching a new drawing in AutoCAD for mac (educational) 2018.  I get a path not found error.
Message 8 of 14
maxim_k
Hi Lisa,
What macOS version do you have on your Mac?
If it is 10.15 - Catalina, then you need to install this update to AutoCAD 2018 for Mac:
Have you installed it?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 14
Mac 2018 for education
Yes, it is installed but when we try to start a new drawing, it says "path
not found".
Lisa
Message 10 of 14
maxim_k
Can you show screenshot of "About AutoCAD" window?
Menu AutoCAD 2018 - > About AutoCAD.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 14
Attached is the error.
Message 12 of 14
maxim_k
Sorry - no attachment.
And I asked you to attach "About AutoCAD" window in order to make sure the update is installed.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 14
Same with me. When I copy and put the CAD files in different folder it respond like these "path not found" when I reopen the file. Cannot rename the files also, because I want to save it in different name. It can open but in READ ONLY FILE setting, cannot edit or revise the drawing.
Message 14 of 14
maxim_k
Hi Mark,
You ask Windows OS specific question on AutoCAD for Mac Forum (different OS).
But anyway, it seems AutoCAD cannot open file because file name is invalid or too long. At the same, as I see from the second screenshot, you cannot rename file in Explorer.
So I think you can try to rename that file using this trick:
https://superuser.com/questions/638123/how-to-rename-a-too-long-file-name
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
