Pasting Excel document into DWF file in AutoCADLT 2026
schristianco
Message 1 of 19
schristianco
I used to be able to do this in an older version I had but can't get it to work in my new 2026. It brings the document in really large and the columns are not aligned. I would do copy and paste special. Anyone found a way to do this successfully in 2026?
Replies (18)
Message 2 of 19
paullimapa
I have no problems copying Excel columns & rows onto 2026...works just like it used to.
Can you share a sample Excel document that you're having trouble copy & paste special into 2026 along with the dwg?
Paul Li
IT Specialist
@The Office
Message 3 of 19
schristianco
See attached. Not sure if the problem is because I have  because I have AutoCAD LT?
Message 4 of 19
paullimapa
Not sure if it's 2026 LT issue.
But I selected your Excel sheet & copied:
Then I opened your drawing in full AutoCAD 2026
With layout DWG TEMPLATE 11x17 set as current I executed the Paste Special command which brought up this window and I accepted the default:
This is what now shows in your drawing:
When you open your attached dwg again in 2026 LT, can you see this OLE?
Paul Li
IT Specialist
@The Office
Message 5 of 19
schristianco
How do you get the Paste Special Command? Under Edit, my options are Paste, Paste Special & Paste to Original Coordinates. I do not see what you did when I open the drawing.
Message 6 of 19
paullimapa
Right after I copied the cells in the Excel sheet I went back to AutoCAD and clicked on Edit menu and this is where I selected Paste Special:
Do you not have this selection on your 2026 LT?
Paul Li
IT Specialist
@The Office
Message 7 of 19
schristianco
No, I do not. I had it on my older version that was upgraded with 2026.
Message 8 of 19
paullimapa
That command selection should still be there since even help file mentions it:
https://help.autodesk.com/view/ACDLT/2026/ENU/?guid=GUID-0223840C-D96F-41E9-8D33-1CEFA8D07B3C
What happens when you enter at the command prompt:
PASTESPEC
Paul Li
IT Specialist
@The Office
Message 9 of 19
schristianco
When I start to type paste on the command line, it pulls up three options:
pasteblock, pasteclip and pasteorig. When I type pastespec, it pulls up
paste block.
Message 10 of 19
paullimapa
that is odd...perhaps you can try resetting LT 2026 or wait till someone else who is also using this version to chime in.
Paul Li
IT Specialist
@The Office
Message 11 of 19
schristianco
How do I reset it?
Message 13 of 19
schristianco
When I did this and opened the drawing, I got the message in the
attachment. Can you walk me through what to do next?
Message 14 of 19
paullimapa
nothing attached
Paul Li
IT Specialist
@The Office
Message 15 of 19
schristianco
Message 16 of 19
paullimapa
Go ahead & click on Open the External References Palette
When I opened your dwg I did see there are a number of files attached but not found.
Usually if these files have been moved or renamed then AutoCAD would bring up this alert window to notify you as you open the dwg.
BTW, are you running AutoCAD LT on a Mac?
Paul Li
IT Specialist
@The Office
Message 17 of 19
paullimapa
AutoCAD LT on Mac does not have PASTESPEC command:
Only Paste commands on Mac are:
AutoCAD LT for Mac 2026 Help | Autodesk
Paul Li
IT Specialist
@The Office
Message 18 of 19
schristianco
Where is the External References Palette found?
Yes, I have AutoCAD LT for Mac.
Message 19 of 19
paullimapa
You should be able to enter the following command to open the External References Palette:
AutoCAD LT for Mac 2026 Help | XREF (Command) | Autodesk
As you can see the Mac version do contain some differences compared to the Windows version.
You may want to post your questions in the AutoCAD for Mac forum here:
https://forums.autodesk.com/t5/autocad-for-mac-forum/bd-p/520
Paul Li
IT Specialist
@The Office
