Orient Annotative Block to UCS in AutoCAD for Mac
bretwieseler
Message 1 of 16
bretwieseler
I've created an annotative block in the WCS.  When I insert it into a drawing using a different UCS, it orients itself to the WCS in which it was created.  Is there a way to create a block that will always remain orthagonal to my view regardless of the orientation of the UCS?
Thanks in advance.
-Bret
@bretwieseler
john.vellek has edited your subject line for clarity: Orient Annotative Block to UCS
-Bret
3.6 GHz 8-Core Intel Core i9 | 13.6.1 | AutoCAD LT for MAc 2024.1
Replies (15)
Message 2 of 16
maxim_k
Hi Bart,
Can you attach drawing with the block you created. This should help to find the answer quicker.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 16
bretwieseler
I've attached the block as you requested.
Thanks.
-Bret
Message 4 of 16
maxim_k
I "reset" your block by unchecking Annotative in Block editor than saving it as non-annotative.
Than I opened it again in Block editor and checked Annotative.
Now it seems to behave correctly.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 16
bretwieseler
Maxim,
I did as you suggested, but the block still comes in at the WCS.  Is there a setting in the drawing that could be prohibiting the block from orienting itself correctly?
-Bret
-Bret
Message 6 of 16
maxim_k
Have you tested the.block I attached to my post? Does it works correctly on your side? Actually it is your block, but edited as I described. Maybe I missed some step in the description of my repair actions, I have to check once again.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 16
bretwieseler
Maxim,
I tested the block you created and it simply maintains the orientation in which it was placed into model space.  If I change the UCS of either model space or the viewport, the block orients with it.
Here is an image to better explain what I would like the block to do:
-Bret
Message 8 of 16
maxim_k
No I understand what you want.
You need to edit block in Block Editor: while you are in Block Editor, look at the Properties palette, find "match block orientation to layout" option and activate it. Save block and test it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 16
bretwieseler
Maxim
Maxim,
I've done as you recommended.  The block inserts according to the WCS (incorrectly), but it does display correctly in my layout.
-Bret
Message 10 of 16
maxim_k
So, is the problem solved now?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 16
bretwieseler
Not really.  I don't want the block to insert into model space oriented to the WCS.  I want it to insert and remain right side up (for lack of a better description) regardless of the angle of the UCS.
-Bret
Message 12 of 16
maxim_k
So you need the same behavior of the block in Model space as you have inside viewport in Layout. Am I correct?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 16
bretwieseler
That is correct sir.
-Bret
Message 14 of 16
maxim_k
The rule of AutoCAD:
If annotative block have "Match layout orientation" option checked, than the block will be inserted without rotation - it always will stay as it was created, and this is true for both Model Layout and Paper space layout.
If the block have "Match layout orientation" option is nit checked, than the block will be rotated regarding current UCS, and this is true for both Model Layout and Paper space layout.
You cannot mix this behavior in one block.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 16
john.vellek
HI bretwieseler,
Perhaps you need to approach this with two blocks: one for the part you don't want rotated and the other block that you do want rotated.
If this works, you could even try nesting one block into the other.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 16 of 16
john.vellek
Hi bretwieseler,
I am checking back to see if you had resolved your issue. Did you try utilizing the two block method?
I created a North Arrow using two blocks. the circle part is set as annotative with Match Orientation. The line part is annotative and set as NOT Match Orientation. I believe this is the desired look you want.
John Vellek
