AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Opening DWG files in AutoCad 2017 Mac when created in AutoCad 2018 for windows
9 REPLIES 9
Message 1 of 10
VAtom
1341 Views, 9 Replies
Hi
Please initially move this to AutoCad boards as i could not post it there
The windows machine is used and we selected to save the file as 2013 but still AutoCad Mac 2017 cannot open it as it was created in a more recent version. The actual error message is this:
The drawing file could not be opened because it was created with a more recent version of AutoCAD
Thanks Tom
9 REPLIES 9
Message 2 of 10
john.vellek
in reply to: VAtom
Hi @VAtom,
When you save the file in the Windows version, are you able to save down to the 2013 file format? Have you also tried an -EXPORTtoAUTOCAD command to get this to work?
Can you attach a sample 2018 file for me to examine?
John Vellek
Message 3 of 10
VAtom
in reply to: john.vellek
Hi
Yes, we are selecting the 2013 option, just tried the command EXPORTtoAUTOCAD and got the same error
The wording of the error concerns me 'created in' not 'saved as'
Will get you a non confidential file for you to try
Thanks Tom
Message 4 of 10
john.vellek
in reply to: VAtom
Thanks Tom
I will wait to see your file.  If the file is CREATED in AutoCAD with any vertical proxy objects then this is not a surprising result.
John Vellek
Message 5 of 10
maxim_k
in reply to: VAtom
Hi Tom,
I have no troubles with drawings created in AutoCAD 2018 for Windows and saved in 2013 format using "Save as" functionality. Such drawings open in AutoCAD 2017 for Mac without any problems.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 10
VAtom
Hi
Here is a test file, created in AutoCAD 2018 for windows. saved as a 2013 DWG and cannot be opened in AutoCAD 2017 for Mac
Thanks Tom
Message 7 of 10
maxim_k
in reply to: VAtom
Hi Tom,
The drawing you attached is in 2018 DWG format. When I open it in AutoCAD 2018 for Windows the command prompt shows:2017-07-18_11-43-55.png
I saved your drawing on my system in 2013 DWG format and attached it to my post.
Please try to open it in AutoCAD for Mac.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 10
VAtom
in reply to: maxim_k
HI
We have saved it as 2013, checked and even our default options are set to save as 2013.
Is it a problem with the windows hardware/software????
Message 9 of 10
maxim_k
in reply to: VAtom
Could be a problem with Windows version installed on your machine, but I've never heard of such a problem with saving in previous format in AutoCAD 2018.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 10
VAtom
i think we have the solution and I have marked it above, simply not being saved correctly, apologies for this
