Offset command
Offset command
eduardedy
Offset command
eduardedy
Hi everyone,
I don't know if I'm the only one having this small (annoying issue).
When I'm using the offset command shortcut, {off followed by space(key)}, the ''unknown command'' is showing. This is happening when I rapidly type ''off and space''. If I'm waiting 1 or 2 seconds after typing and then hit space, the command run.
Any idea?
maxim_k
Hi Eduard,
Standard alias (shortcut) for OFFSET command defined in acad.pgp file is "O".
I redefined it to "OF" and doesn't have any issues.
Have you tried to redefine it from "O" to "OFF" on "Aliases" tab of CUI command?
https://help.autodesk.com/view/ACDLTM/2021/ENU/index.html?guid=GUID-6230DE90-E6D8-4FAC-ACC1-7668F70F...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
eduardedy
Hi Maxim,
Brilliant! Thank you very much. For some reason, in AutoCad 2018, the 'off'' command for offset was working.
Thank you again for your help.
