- Mute
- Permalink
- Report
Hello, this is a somewhat basic question so I will try to be direct:
-I am using a Macbook Pro with a bluetooth keyboard
- When I want to do something like OFFSET, I will type OFF and then the autocomplete menu drops down to show OFFSET.
- I use the down arrow to select OFFSET
- If I press RETURN on the keyboard, it works properly.
- If I press the ENTER key on the NUMPAD, if will display "Unknown command OFF. Press F1 for help."
-If I type OFFSET completely and then press ENTER, everything works fine.
I am aware that on MAC, the Enter key and the Return key have two different functions, though I am not sure if this is the root problem.
How can I get my Numpad Enter key to function the same as the Return key.
Thank you.
