AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
NO PUEDO PEGAR ARCHIVOS EN EXCEL - I CAN'T PASTE FILES INTO EXCEL
4 REPLIES 4
alexcruz8553
122 Views, 4 Replies
TENGO AUTOCAD Y AL MOMENTO DE QUERER PEGAR UN METAARCHIVO EN EXCEL NO ME DEJA NI ME SALE LA OPCION QUE COMPLEMENTO TENGO QUE DESCARGAR?
[translated with Google]
I HAVE AUTOCAD AND WHEN I WANT TO PASTE A METAFILE INTO EXCEL IT DOESN'T LET ME OR I DO NOT GET THE OPTION WHICH ADD-IN SHOULD I DOWNLOAD?
4 REPLIES 4
maxim_k
in reply to: alexcruz8553
Hi @alexcruz8553 ,
If you want to paste AutoCAD drawing to Excel spreadsheet, you can print from AutoCAD to PDF and then insert PDF in Excel.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
alexcruz8553
in reply to: maxim_k
NO ME DEJA COPIAR TAMPOCO EL PDF
I CAN'T COPY THE PDF EITHER
maxim_k
Hi @alexcruz8553 ,
You don't need to copy PDF.
You need to create PDF from your drawing in AutoCAD and then insert it to Excel
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
pendean
@alexcruz8553 On Mac you cannot use copy - paste method to insert drawing data from AutoCAD to Excel, because this is OS specific functionality (AutoCAD for Mac and macOS cannot convert DWG data format to one of vector formats that Excel can read).
The only one way on Mac is to export drawing to PDF file from AutoCAD and then insert resulting PDF to Excel. Of course, you will not be able to edit inserted drawing by double-clicking on it as you can do on Windows side if you are using OLE technology.
https://forums.autodesk.com/t5/autocad-for-mac-forum/problem-with-inserting-autocad-drawing-to-excel...
