NEED SOME HELP!
NEED SOME HELP!
NEED SOME HELP!
I have autoCAD 2015 for mac and i can not print a dwg to pdf with color and I really need the figure with color at the pdf document.
HELP PLZ
maxim_k
Welcome to Autodesk Forums!
Hi Daphnee,
You have several options.
For example, you can uncheck "Plot with plot styles" option in Page Setup for the Layout you are trying to output to PDF. Then AutoCAD will output to PDF with colors, you assigned to objects (or Layers).
Or if you need monochrome output with some colored elements, then use monochrome plot style table and assign True Color to the objects you want to have in color in PDF.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
