Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Need a little help extruding an Illustrator file
11 REPLIES 11
Message 1 of 12
figure1a
520 Views, 11 Replies
I am having a heck of a time trying to extrude and chamfer a shape that I made in Illustrator. Playing around with the file either says it cannot extrude or gives me weird results. Could anyone extrude the shape to .25" tall and then put a .225" chamfer all the way around it for me? I need the file to be a solid when done so I can further add and subtract a few more shapes from it. I have attached 3 files: the Illustrator file, a DWG of the Illustrator file and another DWG that is already extruded to .25". Thanks!
11 REPLIES 11
Message 2 of 12
figure1a
in reply to: figure1a
Here is the shape extruded:
Message 3 of 12
maxim_k
Hi @figure1a ,
I'm afraid this is an impossible task. The result is a heavily distorted 0.225" chamfer:
See attached DWG
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 4 of 12
figure1a
in reply to: maxim_k
Hi Maxim, thanks for taking a look. Maybe Chamfer is the wrong operation? Basically, I want it to look like someone took a knife and cut the edge off all the way around at a 45 degree angle. Surely, this is possible?
Message 5 of 12
maxim_k
Hi Dana,
Have you seen the result in the attached drawing?
AutoCAD refuses to "cut" the edge with the given parameters, so I created a LOFT, but you see the distortions that appear as a result of such an operation.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 12
figure1a
Hi Maxim,
I did see your pic. I think maybe the way that I converted the AI file to DWG is creating many little faces and therefore the chamfer is failing (see pics below). Do you know the correct way to convert the AI file to DWG? When I export the AI file to DWG it results in the first DWG file that I posted. For some reason it makes all those faces (in Illustrator my shape is very simple and has less the 10 control points). Is there a way in AutoCad to remove all those faces or simplify those curves? Maybe if that can be done then the chamfer would work.
Message 7 of 12
figure1a
So, I figured out how to eliminate all those faces. Do you think this is still unchamferable? New DWG file attached.
Message 8 of 12
maxim_k
Hi Dana,
Does the red Solid is what you want to get?
See attached drawing.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 12
figure1a
Yes! How did you do it? AutoCad would not let me ChamferEdge at all. Thank you!
Message 10 of 12
maxim_k
At first I recreated the base shape with PLINE command, because SPLINES from AI seems extremely complex for AutoCAD.
Then I simplified the base shape by removing filleted corners and created EXTRUDE from it, then I was able to use CHAMFER command with 0.225 distance (see white Solid in my drawing).
Then I used FILLET command with desired radius on the corners of the Solid:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 12
alastair_leith
I've been having similar issues with AI files coming in as SPLINES, even when the paths are simple circle arcs and straight line sub-paths. SPLINEDIT does the conversion of Splines to Polylines.
Message 12 of 12
figure1a
in reply to: alastair_leith
Thanks. That's one of the processes that I use but still had no luck here. Sometimes the SplineEdit conversion distorts the shape. Other times, like this, when I extrude it to a solid, it does not behave like a solid.
