Multiply clicks to pick up a node
lrudyd
lrudyd
MacBook Pro, version 14.2.1 Sonoma, running 2024 AutoCAD LT for Mac
When I try to pick up a node - for instance to stretch a line - I have to click on the node 2 to 3 times before it connects. Anyone having this problem with the 2024 version?
maxim_k
Hi @lrudyd ,
If you mean you cannot use grips because of multifunction menu that appears when you pick a grip, you can look at this topic:
Grip menu prevents dragging a grip
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
lrudyd
Thank you, I'll look at that.
johntk22
make sure you are using the latest version of the AutoCad for Mac.
