I think I know the answer to this already, but I'll ask anyway. I want to create an elevation callout with multiple arrows:
Is it possible to have layer states where I can toggle each arrow on/off without having to set up a separate visability state for every possible permutation?
Thanks.
Solved by maxim_k. Go to Solution.
Hi @bret_wieseler ,
I think you can try to create block with arrows on different layers, then you can turn on/off this layers by changing Layer states.
See attached
Thanks Maxim.
I'd like to keep my layers as simple as possible, so I'll try to find another way. We have 1 Windows license of AutoCAD in my office. I wonder if there's a way to achieve this using lookup tables/actions. I'll have to pose the same question in the other AutoCAD forum
Hi @bret_wieseler ,
I think you can create dynamic block with lookup table in PC version of AutoCAD and then use it in AutoCAD for Mac, but you will not able edit it on Mac.
