Multiple fails in AutoCad. Missing tool boards etc
Hi all,
I have multiple problems with my AutoCad:
1) It quits after I try to right click anywhere on the screen; after trying "RESETPALLETES" command
2) does not plot, I am using cmd + p - nothing happens
3) There is no toolbar and no top bar with options (I will attach screenshots)
4) (ref. second screenshot) When I click on any of those options "Item2" or "item3" nothing happens again.
Apart from that all commands work as usual. I had this problem and thought that installing updates will help. Nothing changed once again.
I am also attaching my general settings.
Many thanks in advance!
Nadia
TheCADnoob
This will likely need to be posted in the AutoCAD for Mac forum
http://forums.autodesk.com/t5/autocad-for-mac-general/bd-p/520
CADnoob
pendean
Community Legend
Community Legend
What version of MACOS are you running?
john.vellek
Hi Nadia, Please try a Reset (From the AutoCAD pulldown menu)
Please also let me know your OS and if you have applied service packs 1-4 found here.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
maxim_k
Hi Nadia,
You have a problem with missing menus and Tool Sets palette, which has repeatedly been discussed at the Forum.
At first you need to try this:
https://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticle...
You only need to replace the paths specified in the article in accordance with your AutoCAD version.
I'd recommend you to start with AutoCAD reinstallation - at first clean uninstall  AutoCAD, than install it again. If you have latest OS X version - El Capitan - you need to install all service packs before using AutoCAD.
You can also look here:
http://forums.autodesk.com/t5/autocad-for-mac-general/no-menus-in-top-bar-and-no-drawing-panel/td-p/...
Again you need to substitute 2015 version with 2014.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
