AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Mtext printing outside of frame
12 REPLIES 12
Message 1 of 13
bretwieseler
658 Views, 12 Replies
Hello.
I have a frame around some of the mtext in my drawing that looks fine in model and paper space, but when I print to PDF the text is slightly wider and extends outside of the text frame.  Please see attached image.
Has anyone else experienced this?  Any thoughts as to why this is happening?
Thanks.
-Bret
3.6 GHz 8-Core Intel Core i9 | 13.6.1 | AutoCAD LT for MAc 2024.1
Tags (3)
Labels (3)
12 REPLIES 12
Message 2 of 13
pendean
in reply to: bretwieseler
Font Substitution most likely: are your fonts not set to be embedded? Or are you using a for-pay fonts?
Message 3 of 13
bretwieseler
@pendean The fonts are set to be embedded and the font in question is Arial, so I'm pretty certain there should be no issues.
-Bret
Message 4 of 13
pendean
Good to know: can you then share that DWG and that PDF here for review?
Confirm your AutoCAD year version and MacOS variant too please.
Message 5 of 13
maxim_k
Hi @bretwieseler ,
What Printer do you use to "print" your drawing to PDF?
Have you tried one of the "AutoCAD PDF..." printers?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 13
bretwieseler
in reply to: maxim_k
@maxim_k
I'm using the "AutoCAD PDF (High Quality Print).pc3 setting
-Bret
Message 7 of 13
maxim_k
Hi Bret,
@bretwieseler
Can you share your DWG and resulting PDF here for review as @pendean asked?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 13
bretwieseler
@maxim_k , @pendean
 I've attached a PDF and a packaged CAD drawing.
Thanks for your help.
-Bret
Message 9 of 13
pendean
Thank you so much for your files: I seem unable to replicate your issue, but I do notice your font in the two PDFs (yours and mine) are sized different for sure
Message 10 of 13
bretwieseler
in reply to: pendean
Thanks.
Interesting.  DO you think it could be an issue with Acrobat and not AutoCAD?
-Bret
Message 11 of 13
maxim_k
Bret,
I also cannot reproduce this issue on my side - tried in AC 2019, AC 2022 and AC 2023.
But when I opened the resulting PDFs in Affinity Designer, I noticed that in your PDF text height is 3.6mm (10.1 pt) and in PDFs, created on my Mac it is 3.3mm (9.4 pt).
I also noticed that in the archive with your drawing you provided, there is ArialMdm.ttf font, which is not visible to AutoCAD even it is installed on my system.
How do you use this font in your drawing?
And another question: have you installed all Updates to your AutoCAD for Mac 2021? The last one is 2021.3 Update which includes all Updates.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 13
maxim_k
Thanks.
No, it is not Acrobat issue.
Try to open attached PDF on your Mac.
Do you see correct font size?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 13
bretwieseler
I cleaned the fonts on my system and resolved duplicate fonts and now the problem is fixed!
Thanks everyone for the suggestions.
-Bret
