Is there a way to have the leader arrow emerge from the top of bottom of the content block?
Please see the attached image.
Solved by maxim_k. Go to Solution.
Create custom block for mleader style with insertion point in the middle of the upper side of the box.
Than use it in Multileader Style with this settings:
See attached DWG - "Copy of Standard" Multileader Style.
Maxim
Thanks for your response Maxim-K. Does that mean I have to have a separate leader style depending on which side I want the leader to come out of? Ideally I would have an mleaderstyle that allowed me to move and adjust the leader as necessary and it would always emerge at a 90° angle from one of the sides.
-Bret
Hi Bret,
Sorry, I thought you was asking about only Top attachment.
Please try mleader style with name "002" in the attached drawing.
When you will create mleader - enable ORTHO.
Does it suits your needs?
Maxim
Thank you, Maxim.
That works perfectly.
