Migration from Time Machine
Needed to restore from Time Machine to a new Macbook Pro as my previous was recently stolen.  When I try to open Autocad for Mac I get a link to this info on AutoDesk.  Problem is I do not see a 'FLEXnet' Publisher Folder in my 'Preferences' folder as noted below.  No idea how I'm supposed to restore my Acad.  Please advise.  Thanks
Issue:
You use the Migration Assistant to migrate data from another hard drive (or you restore from a Time Machine backup) and the data being migrated or restored to your system drive includes a FLEXnet Publisher folder.
After migration, you successfully install AutoCAD for Mac, but the program fails to launch.
Causes:
When a FLEXnet-enabled product is installed on a Mac, a FLEXnet Publisher folder is created in /Library/Preferences. This folder is where FLEXnet creates the trusted storage files for each FLEXnet-enabled product running on the system.
When this folder is migrated using the Apple Migration Assistant, or restored using Time Machine, these utilities save metadata onto the folder. When metadata is attached to the folder, FLEXnet is not able to create the trusted storage files required to launch and run AutoCAD.
Solution:
Workaround: Rename the existing FLEXnet Publisher folder and then uninstall and reinstall AutoCAD for Mac. This will create a new FLEXnet Publisher folder where FLEXnet can create the trusted storage files and AutoCAD will be able to successfully launch.
Note: The FLEXnet Publisher folder is located in the /Library/Preferences folder at the root of the local hard drive. For example:
Macintosh HD > Library > Preferences
This folder is NOT located in the /Library/Preferences folder under /Users:
Macintosh HD > Users > "UserName" > Library > Preferences
To rename the folder:
Open a Terminal window (the Terminal app is typically found in the /Applications/Utilities folder).
Type (or copy and paste) the following, all on one line:
sudo mv /Library/Preferences/FLEXnet\ Publisher /Library/Preferences/FLEXnet\ Publisher_old
Press return and provide the admin password when prompted (the password will not be echoed to the screen).
Quit the Terminal application.
After AutoCAD has been reinstalled, copy all files and folders from the FLEXnet Publisher_old folder into the new FLEXnet Publisher folder except any files that begin with "adskflex." This retains the trusted storage files used by other products, such as Adobe, without keeping any older Autodesk files.
Note: The FLEXnet Publisher folder is not owned by Autodesk but is owned by Flexera, makers of the FLEXnet licensing technology used in Autodesk products. This solution is offered as one possible method of resolving this issue and is up to the discretion of the customer.
maxim_k
Welcome to Autodesk Forums!
You need to reinstall AutoCAD: remove it with Remove AutoCAD application and then install again.
After installation you will be able to activate AutoCAD.
Don't forget to update AutoCAD with all Service Packs (Updates).
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Thanks. And yes performed that last evening after not know what else to do. Took a couple attempts to re-activate, but appears to running fine now. Thanks again.
Scott Roeder
StudioROEDER
2902 east earll drive phoenix, arizona 85016 602.561.4344 m 602.522.9022 f websitefacebook
Please consider the environment before printing this e-mail.
© Copyright 2016 StudioROEDER. Items of this email in connection to StudioROEDER are the exclusive property of StudioROEDER and are protected under U.S. and international copyright laws. The contents of this email may not be reproduced, copied, stored, encrypted, transferred or manipulated without the written permission of StudioROEDER. StudioROEDER is not responsible for any and all damage caused by any virus or any other programs that may be contained in this electronic media.
