macOS Sierra Preview hangs with batch PDF
Message 1 of 15
In mac OS 10.12, Preview hangs & displays the spinning beach ball forever when viewing a Batch PDF created in AutoCAD LT 2017.
All other non-batch PDF files load without any problems in Preview. The same batch PDFs hanging Preview, open fine in Acrobat Pro.
This is on a 2011 iMac with 16GB of RAM, 240GB SSD & new install of Sierra. All the latest macOS, Adobe & AutoCAD updates have been installed.
Replies (14)
Message 2 of 15
maxim_k
Welcome to Autodesk Forums!
Hi Nicole,
Which preset you are using in Batch Publish window? Is it a single or multiple sheet PDF?
Does this happens with all of your drawings or with just one?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 15
Hi there,
On Wednesday it was any file that was more than one page. Now it only seems to be some files.
Thank you,
Nicole
Message 4 of 15
maxim_k
Can you attach here one of the problem PDFs?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 15
Here is the PDF.
Message 6 of 15
maxim_k
Sorry, but there is no attachment 😞
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 15
maxim_k
If you are using email to answer, then there will be a problem with the attachments, please use WEB browser instead.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 15
Hi Maxim,
I was using my email. Let me know if this works.
Message 9 of 15
maxim_k
I see it now, will look at it little bit later
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 15
maxim_k
Nicole,
No problems with opening and viewing this PDF in Preview app on my side (macOS 10.12.5, Macbook Pro 15" late 2013).
The file opened in the application almost instantly.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 15
pendean
Community Legend
Community Legend
Just so we are all clear, what are you calling "preview" please?
Are you saving your files or PDF to a NAS drive by chance?
Message 12 of 15
"Preview" is the Mac application used to open up PDFs. I don't think I am saving files to a NAS drive.
Message 13 of 15
john.vellek
HI @Anonymous,
I took a look at your PDF and had no issues opening it in Preview.
Is it possible to PACKAGE a sample set of files that you are using to create a Publish PDF?  I would like to see the files, the plot settings and if you could also describe your process in creating the Publish PDF it would be helpful
John Vellek
Message 14 of 15
wei503
Last year I myself ran into situation that the Preview hangs when open any files, and I did not find a way to fix it. I searched in Apple forum and it seems to be an issue in the Preview app. My suggestion is to use the Acrobat PDF reader instead, or reinstall the OS.
Wei
Wei Ma
AutoCAD QA Manager
Message 15 of 15
john.vellek
Hi @Anonymous,
Did @wei503 resolve your issue with the great suggestions? If so, please reward the post that worked with a Kudos and please also mark a post or posts as Accepted Solution(s) that resolved the issue.
John Vellek
