MacOS Sequoia and AutoCAD - anyone upgraded yet and tested?
moneumiko
Message 1 of 72
moneumiko
I'm eager to upgrade the system now but I'm wondering if this would affect my AutoCAD in any way.. Anyone upgraded and can confirm if AutoCAD works as normal?
Replies (71)
Message 61 of 72
vkasimoglu
This is my AutoCAD 2025
I'm also sending my iMac.
Message 62 of 72
maxim_k
Hi @vkasimoglu ,
@vkasimoglu wrote:
Now when I try to install 2025.1 it says "This update or a newer one is already installed".
The 2025.1 Update is already installed on your Mac.
Here is a screenshot from your post:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 63 of 72
vkasimoglu
Yes... I know that. The problem is; it doesn't work.
Still
1- "File/Save As" doesn't work
2- "Print/Save as pdf" doesn't work
But the problem is in Sequoia. Because I didn't uninstall the 2024 version in case there was a problem with the 2025 version and I see the same problems in 2024. These problems weren't in 2024 or 2025 before.
Message 64 of 72
moneumiko
Maybe sequoia doesn't like Intel macs too much.. If that's the case, maybe they will release an update that will fix this issue for intel devices.
Message 65 of 72
vkasimoglu
Maybe... Most probably Apple wants us AutoCAD users to change our intel iMacs to Mac Studio/M2. Because they don't produce 27" iMac anymore.
Message 66 of 72
vkasimoglu
After too many problems, I uninstalled Autocad 2025 LT and downloaded it again and reinstalled it. This time I did not migrate my old settings. In other words, I reset everything. I did not install the 2025.1 update as well.
Now, everything works normally.
Message 67 of 72
vkasimoglu
After two days of my re-installation,  "File/Save as" and "Print/Save as pdf" is not working again.... 😤😤
Message 68 of 72
moneumiko
Sorry to hear that... Maybe you'd benefit from upgrading your hardware? Just a thought..
Message 69 of 72
pendean
Community Legend
Community Legend
Here are the ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
and
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Contacting-a-techn...
Message 70 of 72
lovialle
Observer
Observer
Same problem on new IMAC M4 16gbRAM Sequoia 15.2, Autocad LT 2025 crash every 30 minutes..
tried to disable auto savings, and some options, but still crash.
Crash when I work on Dropbox file (cloud) or when I work with a file on my SSD Drive, even with new clean files..
Autodesk , got a solution ? soon ?
Message 71 of 72
vkasimoglu
thanks for your comment. I was thinking that it happens to me because of my old 2020 iMac and was ready to buy new one. Now it seems that it is a software problem.
Message 72 of 72
pendean
Community Legend
Community Legend
@lovialle wrote:
...Autodesk , got a solution ? soon ?
@vkasimoglu
... it happens to me because of my old 2020 iMac...
You need to reach out to Autodesk yourself, they don't come into these forums for anything, never have.
