I'm eager to upgrade the system now but I'm wondering if this would affect my AutoCAD in any way.. Anyone upgraded and can confirm if AutoCAD works as normal?
This is my AutoCAD 2025
I'm also sending my iMac.
Hi @vkasimoglu ,
@vkasimoglu wrote:
Now when I try to install 2025.1 it says "This update or a newer one is already installed".
The 2025.1 Update is already installed on your Mac.
Here is a screenshot from your post:
Yes... I know that. The problem is; it doesn't work.
Still
1- "File/Save As" doesn't work
2- "Print/Save as pdf" doesn't work
But the problem is in Sequoia. Because I didn't uninstall the 2024 version in case there was a problem with the 2025 version and I see the same problems in 2024. These problems weren't in 2024 or 2025 before.
Maybe sequoia doesn't like Intel macs too much.. If that's the case, maybe they will release an update that will fix this issue for intel devices.
Maybe... Most probably Apple wants us AutoCAD users to change our intel iMacs to Mac Studio/M2. Because they don't produce 27" iMac anymore.
After too many problems, I uninstalled Autocad 2025 LT and downloaded it again and reinstalled it. This time I did not migrate my old settings. In other words, I reset everything. I did not install the 2025.1 update as well.
Now, everything works normally.
After two days of my re-installation, "File/Save as" and "Print/Save as pdf" is not working again.... ![]()
Sorry to hear that... Maybe you'd benefit from upgrading your hardware? Just a thought..
@vkasimoglu wrote:After two days of my re-installation, "File/Save as" and "Print/Save as pdf" is not working again....
Here are the ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
and
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Contacting-a-techn...
Same problem on new IMAC M4 16gbRAM Sequoia 15.2, Autocad LT 2025 crash every 30 minutes..
tried to disable auto savings, and some options, but still crash.
Crash when I work on Dropbox file (cloud) or when I work with a file on my SSD Drive, even with new clean files..
Autodesk , got a solution ? soon ?
@lovialle wrote:...Autodesk , got a solution ? soon ?
... it happens to me because of my old 2020 iMac...
You need to reach out to Autodesk yourself, they don't come into these forums for anything, never have.
