HI @Anonymous,
I see that you are visiting as a new member to the AutoCAD for Mac forum. Welcome to the Autodesk Community!
The only issues I think you might have other than file format as suggested by @Anonymous, is with fonts or linetypes. The instructor would need the same fonts as those installed on your Mac. You can use PACKAGE (eTransmit) to include them when you send your file to your instructor.
You might also have some problems with Page Setups but they are not likely to cause any major problems.
You are more likely to have problems receiving files from Windows AutoCAD because the Mac version does not have Object Enablers.
If you want to explore the drawing transfer you can install Bootcamp on your Mac, install Windows in the new partition and then install Windows based AutoCAD. This allows you to work in the Mac environment if you pefer and then transfer to the Windows version to test for any problems.
John Vellek
