Running your company's version of AutocadLT at 13 inches with the 2020 M1 MacBook Pro will cause screen problems such as attached images.
Is it a problem with optimization or setup within a program?
I would appreciate it if you let me know if you have a solution.
Solved by maxim_k. Go to Solution.
Welcome to the Autodesk Forums!
Hi @Anonymous
Have you installed AutoCAD LT for Mac 2020.2 Update?
https://up.autodesk.com/2020/ACDMAC/AutoCAD_and_AutoCAD_LT_For_Mac_2020.2_Update_Readme_ENU.htm
You can download this Update from your Autodesk account page:
I am facing the same issue as @Anonymous .. only this time its for Autocad LT 2021 which I downloaded from the Autodesk site.
Can someone please advise.
Thanks in advance!
Ok i found the solution at
Thanks guys
