LT 2013 etransmit
LT 2013 etransmit
LT 2013 etransmit
is there a command similar to "etransmit" from the windows version??  Also - is there a way to set Lt2013 to always "save as 2010" for example
maxim_k
No e-Transmit, or even similar too... Smiley Sad
But here is a trick, if you have Internet connection:
Save your drawing, use File -> Upload Drawing Online (create AutoCAD WS account if you don't have it already, or just Login to autoCAD WS).
Wait for message "Open online", open drawing in your default WEB Browser.
In AutoCAD WS select drawing you just uploaded, select Download .ZIP (with xRefs).
Save ZIP file to your Mac.
Inside saved ZIP archive you will find your drawing with all xRefs DWG and images. Unfortunately this trick doesn't work with attached PDFs, fonts, CTB-STB files (if any).
HTH
About Save As 2010, please look here - should help if you have "non-AppStore version":
http://macacad.wordpress.com/2012/09/03/setting-default-format-for-save-in-autocad-lt-for-mac/
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
thank you - for both answers.....
wow - thanks - i will try that - Smiley Happy
that is spectacularRobot Happy - thanks
