Lookup Point or visibility State in Dynamic blocks
Can I create two 'Visibility State' points in a block?
If yes: How?
On a PC (under parameters) I can create 'Lookup' points. I do not see this option on a mac. Can I create Lookup points on a Mac?
If Yes: How?
Please tell me how. I'm completely stuck and out of options.
Geert
maxim_k
Welcome to Autodesk Forums!
Hi Greet,
Creation of "Lookup points" is not available in AutoCAD for Mac. You can only create ordinary Visibility states in AutoCAD for Mac.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Maxim,
Am I correct to assume, only one visibility state point can be created per block?
maxim_k
No, you can create as many Visibility states as you want, but Lookup actions is not available on Mac.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Maxim,
This is a bit confusing:
I understand that within a visibility state point, I can create as many visibility states as I want: For example: I can create a block with a visibility state point where I can choose between a cirkel, a triangle and a cube.
Now, within this block I would like to copy the same visibility state point, (or create another new visibility state point) with the same cirkel, triangle and cube.
Within one block there would be two visibility state points where (from each point) I can choose if I want the cirkel, triangle or the cube.
I cannot seem to create this. There is only one visibility state point I can create.
Can you help me?
maxim_k
So you want to create "top-level" visibility state that allow you to select between two other visibility states?
If you mean functionality equivalent to PC version, than it is not available on Mac.
This is one of limitations of Mac version.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
OK. That's what I thought.
Thanks for the reply.
