Linear Parameter Not Showing
Hi All!
I'm having an issue where a Linear parameter added in the block editor is not showing once I exit back into model space.
Any Ideas?
maxim_k
Welcome to Autodesk Forums!
Hi Ryan,
After you add linear parameter to dynamic block, you have associate an action with this parameter which will allow you to change dynamically contents of the block:
https://knowledge.autodesk.com/support/autocad-for-mac/learn-explore/caas/CloudHelp/cloudhelp/2018/E...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Leaf.chai
Hi Ryan,
To enable the dynamic grip for linear parameter, you need to assign action to that parameter to define the behavior: Move, Stretch or anything else.
To easily specify the action, you can double click the parameter in Block Editor Space. It will as you to assign action:
Hope this topic will be helpful for you.
Leaf
AutoCAD Test Engineer
Leaf Chai
AutoCAD QA Analyst
