Recently I've noticed a difference in the appearance between select linetypes in different drawings. Please refer to the attached image and .dwg files.
Both drawings were started from the same built-in AutoCAD template. Both use the same built-in line type. LTSCALE, MSLTSCALE, PSLTSCALE, and CELTSCALE are all set to "1" in both drawings. If anyone has any insight into this, I'd appreciate the help
Solved by maxim_k. Go to Solution.
Hi Bret,
This is because Standard text style which used in the linetype definition has 0.0625 height assigned in the Drawing1.dwg:
but it should have zero height to display correctly in line type, as it is in the Drawing2.dwg.
