So I just got this new job, and haven't used Autocad in probably close to 3. So these questions are more than likely going to be a quick fix.
So whenever I start a new project It defaults to Decimal units. Is there a way to make it default to Architectural?
Also, I do alot of work that requires the square-footage of areas, and it always shows square-inches - I can see sq ft when I hover over it, just wondering if theres a way to make sq ft the default as well.
Lastly, the line length display in the properties tab just disappeared - How would I go about getting that back in the properties tab?
Welcome to Autodesk Forums!
Hi @Anonymous ,
First, let me ask you: Which version of AutoCAD are you using? And what macOS you have on your Mac.
Use menu File -> New drawing (NEW command) and select acad.dwt as a template, then use menu Format -> Units and set Type of Length to "Architectural":
Not sure about getting information about an area when you hover mouse over an object in AutoCAD for Mac, because it doesn't show info about area (that is why I asked my first two questions). But if you mean you can see an area in Properties Inspector, that there is no way to set sq feet as default area units, AutoCAD always show sq feet it in brackets after sq inches.
I can see line length in Properties Inspector on my side. Verify that you have "All" properties active on the top of Properties Inspector:
