Layers
Layers
Layers
Hopefully a simple question for someone - my 'Layers' window keeps turning itself off !
Properties Inspector, Tools, Commands etc all stay on but not layers.
Any clues as to how to remedy this ?
Andy
maxim_k
Hi Andy,
Which AutoCAD version do you have? macOS version?
Is Layers palette docked or it is in floating position?
Do you use second (external) display?
When it turns off? Can you reproduce the issue with exact steps?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
Can you also share screenshots:
- when Layers palette is on (visible)
- when it is "turned off" (invisible)?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Hi Maxim,
Thanks for your help
AutoCAD LT for MAC
Yes I use a second display (larger screen) at my desk
When I go to 'Window' and click on Layers it turns on and I see it on the screen for a few seconds then just turns off.
(Screen shot attached)
Andy
maxim_k
Please, look at the screenshot:2019-01-04_16-53-22.png
Try to use button #1 to unhide Layers palette permanently.
Or you can undock Layers palette with button #2 - the same way as you did with Properties palette.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Perfect - thank you very much Maxi
Much appreciated
Andy
