Hi
I am trying to use '-Layer' > A > I , to import a Layer State that I saved in another drawing.
It does import the layers when I type the name of the layer State that I saved in another drawing
but
The Layer colour for all layers that I imported is shown as white.
Any solution ?
Regards
Sreejith. S
Landscape Architect
Solved by maxim_k. Go to Solution.
Hi Sreejith,
In order to complete the import you need an additional step - restore Layer state with R option:
-LAYER Current layer: "0" Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: a Enter an option [?/Save/Restore/Edit/Name/Delete/Import/EXport]: R Enter name of layer state to restore or [?]: test Enter an option [?/Save/Restore/Edit/Name/Delete/Import/EXport]: Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]
Maxim
Dear Maxim,
Thanks a ton. This problem had been irritating me since last two hours.
Regards
