AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Is there a way to stop dimension line from breaking automatically?
4 REPLIES 4
sehyun0701
352 Views, 4 Replies
Hola
Simple question : Is there a way to keep the dimension line between the texts from breaking?
am using lt for mac
there prbbly is already someone who asked..but cannot find it!
4 REPLIES 4
pendean
in reply to: sehyun0701
DIMTAD system variable is explained in HELP, you want ABOVE not "centered".
More from HELP https://knowledge.autodesk.com/support/autocad-for-mac/learn-explore/caas/CloudHelp/cloudhelp/2019/E...
HTH
maxim_k
Hi @sehyun0701 ,
If you already set dimension text Vertical position to "Above" (DIMTAD=1), you can use special control code to add second line to dimension text - \X (backslash+uppercase X):
<default dim text>\X
The text should look like:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
sehyun0701
in reply to: maxim_k
\X is exactly what i needed thank you once again maxim!
didn't even know this control code thing even existed. i should check out if there are more of these codes. thank you!!
maxim_k
@sehyun0701 wrote:
..... i should check out if there are more of these codes. thank you!!
Hi Sehyun,
You can look here:
https://adndevblog.typepad.com/autocad/2017/09/dissecting-mtext-format-codes.html
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
