AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Is there a way to change the color of the dark Theme as it was in 2019
6 REPLIES 6
1894 Views, 6 Replies
Hi there. Thank you in advance to enter to this post.
I really don't like this new "Dark Theme blueish Color" in the new ACad2020 for Mac. You can see in the left of this picture the actual color and in the Right the ACad2019 the DarkGray.
Is there a way to change or have the preview Gray color back in the ACad2020 ?
I only found to change to Light / Dark Theme in the Preferences >Looks and Feel, but I can't edit that
Thank you.
6 REPLIES 6
maxim_k
Hi Nicolas,
There is no official way to change colours of Dark Theme back to 2019 "Dark grey".
The only way I've found is to edit two files inside AutoCAD application folder:
- Themes.xml - inside /Applications/Autodesk/AutoCAD 2020/AutoCAD 2020.app/Contents/Frameworks/AcTheme.framework/Versions/Current/Resources folder
and
- main.jsbundle - inside /Applications/Autodesk/AutoCAD 2020/AutoCAD 2020.app/Contents/PlugIns/AcAdvanceToolSet.bundle/Contents/Resources folder
The last one contains information about colours of Tool Sets palette.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
Hi @maxim_k  , thank you for your feedback.
I Replace both files that you tell me from Acad 2019, and I get this...
Only that column of Drafting change the color.
maxim_k
Something wrong with Themes.xml
You can try attached file. Unzip it before placing into correct place.
Hope you created backup of original files.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Perfect @maxim_k . Thank you very much !
With you Theme.xml now I have the Acad 2021 with a gray color !
Thank you !
manilall
Hello, is there any chance you could provide both files please? The additional main.jsbundle file also?
Not a fan of this blue colour.
Many thanks.
TerryDotson
in reply to: manilall
Same here.  I can't believe this was actually listed (Windows + Mac) as an improvement.
Technology Administrators
