Incorrect dynamic block behavior
I have created a dynamic block which works perfectly fine in the file I use as a block library.
The problems start when I load the library into a new drawing and insert a block. Suddenly the behavior is erroneous both stretching and rotating only adjust some of the geometry within the block and not all of it.
I have tried reloading the library and redefining the dynamic blocks but nothing seems to work.
Also when adjusting the dyn. block (rotating or stretching) you see a correct representation on the screen only when you finish the command by pressing return only part of the geometry adjusted.
Extremely frustrating, any help is welcome!
Note: I have been careful in how the block was constructed keeping everything in layer 0 .
Inserting the dynamic block in a new drawing doesn't cause the issue so I suspect there is a setting in the current drawing which causes the issue?
