AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Imported image JPEG turns out black when plotted...
23 REPLIES 23
Message 1 of 24
17801 Views, 23 Replies
Hello Guys,
I have a problem and I hope someone can help me!
I've tried to plot a image but when I do it comes out black.
A friend tried it on a windows version of Autocad, than it comes out normal...
The image was inserted -> references -> selected image in map -> It shows in the lay-out-> than It turns out black.
Does someone know a solution for this problem?
Thanks.
Tags (1)
23 REPLIES 23
Message 2 of 24
maxim_k
Welcome to Autodesk Forums!
Have you tried to open JPG file in some raster editing application on your Mac and reserve it under another name, than attach re-saved image to the drawing?
Maybe something wrong in the image itself?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 24
in reply to: maxim_k
Thats what I thought..
I asked my friend to send the image he had used.
But it also turned out to be black. Smiley Frustrated
Message 4 of 24
maxim_k
I mean that something could be wrong with the image on Mac side.
Are you sure it is really jpeg image? Maybe it is in another format, but has JPG extension.
Can you attach the problem image here?
I'll look at it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 24
Ah oke,
These are the images I tried to use.
Thanks for trying to help.
Message 6 of 24
maxim_k
Everything looks fine on my side - AutoCAD 2016 for Mac, new drawing, monochrome plot style table.
See attached PDF.
Do you use custom plot style table for the page setup in your drawing?
Have you tried to insert images in new drawing and test exporting to PDF?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 24
john.vellek
Hi @Anonymous,
I too am able to see the images, attach them in a drawing and plot them to a PDF. See attached.
What printer drivers do you have installed and which version of AutoCAD for Mac are you using?
Can you attach a screenshot of what your pagesetup looks like?
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 8 of 24
in reply to: john.vellek
Hello Guys,
I tried to plot the images and they appear!
But once i added the image in my layout the image appears in black...
All with the same page setup.
Message 9 of 24
john.vellek
Hi GysRO,
I am sorry that you are still facing this problem. Can you please attach your drawing with the images so I can take a look for you?
John Vellek
Message 10 of 24
maxim_k
Does it appears in black as soon as you add it to the layout?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 24
Thanks for trying,
In this drawing the images appears in black.
Message 12 of 24
john.vellek
Hi @Anonymous,
I am able to print it  a PDF ok (see attached). Can you do this too? If not, perhaps there is something in your print settings. Can you attach your CTB file and also show me your standard print settings?
John Vellek
Message 13 of 24
No it turns out black.
Do you mean this?
Message 14 of 24
john.vellek
Hi GysRO
Let's try this please.
I have installed a driver for the HP PageWide XL series. With that as my default system printer I do not get the black showing up on a PDF.
Could you try installing the same driver? It will try to look for the actual device but you can put in a dummy IP address instead.
From your screenshot I also assume you aren't using any third-party PDF software as a driver.
John Vellek
Message 15 of 24
john.vellek
Hi GysRO,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 16 of 24
Hi guys,
You may have resolved this issue already but just in case you haven't. I realized that I encounter the image (jpeg my case) turns black when plotted is when I applies XCLIP to the reference file the image belongs to. For example, I have my company's logo jpeg in the title block which is referenced into my plan drawing. I did some xclip to the title block and the blackout happened on plot and disappeared if I turned off the XCLIP.  So, I am still interested if there is a solution on that. Cheers
Message 17 of 24
stef.smoldersBT36N
I am having the same problem, do you have a solution?
Message 18 of 24
maxim_k
Hi @stef.smoldersBT36N ,
Please look >>>>here<<<<
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 19 of 24
This link refers back to the same post. Do you mean the answer is on this page?
Message 20 of 24
It links to:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
