IMPORT templates PAPER SPACE
earthsquare
earthsquare
I need to import, templates I have created in PAPER SPACE in a particular drawing
> to another dwg that I am currently working on.
How do I do that ?
Thanks in advance
Regards
Sreejith.S
Sreejith.S
Landscape Architect
maxim_k
In QuickView Drawings window right click on empty area on the right side, where you see Layout thumbnails, select "New Layout From Template" from context menu.
In "Select Template From File" dialog navigate to the template with Layout you want to insert to the current drawing, select it and click on "Open" button.
Select Layout name you want to import in "Insert Layout(s)" window, than click on "Insert". Layout will be imported to the current drawing.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
earthsquare
Thanks Maxim.
I am not familiar with .dwt files. always used to depend on design centre.
let me learn how to make a dwt file.
Regards
Sreejith.S
Landscape Architect
earthsquare
Its so easy.
Regards
Sreejith.S
Landscape Architect
earthsquare
An alternative to your answer would be 'QNEW' command. 🙂
Regards
Sreejith.S
Landscape Architect
earthsquare
QNEW is a different command. sorry for the confusion.
Sreejith.S
Landscape Architect
