I can't use the QuickCalc: Unknown command
I feel like something is missing in the version of AutoCAD 2020 for Mac. I can't find the QuickCalc nor by commands (QC,QUICKCALC) nor by adding it to the ribbon. This is what it shows when I try to use it: Command: '_quickcalc Unknown command "QUICKCALC". Press F1 for help.
I already reseted AutoCAD and installed the last HotFix, but it didn't work.
pendean
Community Legend
Community Legend
Is QUICKCALC or CALC listed in HELP as a command in your version?
Is it QUICKCALC
maxim_k
Welcome to Autodesk Forums!
Hi Diego,
QUICKCALC is not available in AutoCAD for Mac.
Inside AutoCAD for Mac you can use only command line version calculator - CAL:
https://help.autodesk.com/view/ACDMAC/2020/ENU/index.html?guid=GUID-335A5FC6-7D8F-47CA-B479-26655CDE...
You can use this command transparently inside another command for calculations by adding ' before the command name:
'CAL
If you have full AutoCAD, you can also use AutoLISP expressions for calculations.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
