How to uninstall app LTU?
marco_omini6ZKQM
Observer Observer
marco_omini6ZKQM
Observer
Observer
Deleting all the Autodesk files and folders as descridved in : https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Clean-uninstall-of...
Once restarted the Mac files and folders still there and the app still present
This effect the activation of Acad2024
maxim_k
Hi @marco_omini6ZKQM ,
What macOS version do you have on your Mac?
Are you sure that after using "Delete AutoCAD.app" it is not actually removed from the application folder?
Can you share screenshot of the contents of Application folder after you use "Remove AutoCAD.app"? - Before and after restarting your Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
marco_omini6ZKQM
Observer
Observer
Ciao Maxim,
I confirm that procedure to delete and uninstall han been followed and at the end the icon of the LTU still there and after restarting the Mac all the files again appear.
maxim_k
In the screenshot you showed not the contents of the Applications folder, but the Launchpad which tells nothing about the place where LTU app is located.
By default LTU app should be inside /Applications/Autodesk/Adlm folder. If you decided to remove all Autodesk software from your Mac, you can simply move this Adlm folder to the Trash.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
