AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
How to set default properties for text?
3 REPLIES 3
1783 Views, 3 Replies
Hi everyone,
Here's my question: I'd like to input all my text (multi text) with following properties:
Justify: central center
height: 6
rotation: 90
But the default properties are not defined like this so I have to change them every time I creat a text, or use copy properties.
How can I set the default properties as I like?
Thanks!!
3 REPLIES 3
maxim_k
Welcome to the Autodesk Forums!
You can use this macro to create new menu item or a button on ToolSets palette:
^C^C^P(progn (initdia) (command "._MTEXT" (getpoint) "_J" "_MC" "_H" 6) (command pause) (command "._ROTATE" "_L" "" (getvar "lastpoint") 90) (princ))^P;
Select all text above (from ^C... to ;), copy it to clipboard, call CUI command, in Command tab click on + above command list (1), this will create new command "Command1", you can rename it on the right side(2). Then insert macro into Macro field.(3)
Then switch to Menu or ToolSets tab and drag new command to desired place. For ToolSets it is better to add some icon (4) in order you can recognize new command on toolSets palette.
Click OK and use new command.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
in reply to: maxim_k
Or you can use attached AutoLISP routine (you have to extract contents of ZIP file). After you load it with APPLOAD command you can use new RMT command at command prompt to start creation of rotated MTEXT.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Hi Maxim,
Thanks a lot this works very well !
Smiley Very Happy
