AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
How to resize Lower Toolbar in Layers Palette
2 REPLIES 2
622 Views, 2 Replies
I must have clicked something wrong but suddenly I cannot resize the lower toolbar in the Layers Toolbar Palette. Up until today the Lower Toolbar also included a readout of all the data of the objects I have selected (layer, colour, linetype etc.). Now, all I get is the search field for layers. It seems like I turned off a feature or part of the palette. Does this make sense? I may not be describing the parts correctly. At the bottom of the Layers Palette, below the Lower Toolbar was another palette that contained the data noted above (layer, colour, linetype etc. when you select an item).
I can't seem to find this issue on the forum search feature.
Screenshot attached.
Grant
2 REPLIES 2
maxim_k
Hi Grant,
It is not a lower part of Layers palette, but it is Properties Inspector which shows together with Layers palette by default.
To bring it back you can use Cmd+5 shortcut which actually is a toggle for show/hide Properties Inspector, or use menu Window -> Properties Inspector.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
Maxim,
Thank you very much for your reply and solution. I just could not figure that one out. I appreciate your help. All the best, Grant
